Maddy's avatar
Maddy
9 years ago
How to get parent Item type recursively
I have structure where, I have to find all the parent Item in my BOM tree, so How to find it by aml query, or  any server side method for finding all parent Item in BOM.
  • Actually I write AML query for getting all parent item. In my bom tree I want parent Items (with all properties). i.e I run AML query on item which is at 2nd level in bom, so I want Its parent and Parent's parent (with all) property. Is there any reverse method to do this?
  • Hi Maddy, As I understood your query, your are trying to do reverse operation using GetItemRepeateconfig. You can try below AML then, <AML> <Item type="Part BOM" action="get" repeatProp="source_id" repeatTimes="2" select="source_id(name)" > <related_id> <Item type="Part" action="GetItemRepeatConfig" select="name" id="{your bom part id}"></Item> </related_id> </Item> </AML>
    • TU_YINING's avatar
      TU_YINING
      I've tried this and it doesn't repeat since you put the fix id to the related_id's Item. It always do one level I think.
