Hargul_Sidhu's avatar
Hargul_Sidhu
2 years ago
How to find ECR, ECO, EDR associated with PR using API GET call?
Hi, I need the data for all the PRs and ECR, ECO, EDR etc associated with the PR.  By associated I mean the ones that show in the "where used" section of PR and not the relationships.  In other ...
  • asebastian's avatar
    2 years ago
    Hi Hargul,
    I think the best way to achieve this would be to utilize a Query Definition(QD). A QD can traverse a relationship in both directions, including your "Where Used" scenario. The first step would be to build a query definition which starts with PR and uses a Referencing Item relationship to query the items which reference the given PR.
    Once you have a query you're happy with I recommend taking a look at this forums post where someone needed to get a query response via the Rest API. You'll have to create a quick method which calls your QD, and then the method can be called via a POST request.
    AJ
