With the introduction of the RESTful API in 11.0 SP12, you can now get data from Innovator in a JSON format. This JSON can be easily serialized into an object in JavaScript by using the standard JSON.parse() function or in C# by using Newtonsoft's Json.NET library. I think this is the easiest way to handle the data since you can look up properties using code like item.id or item.item_number. However, this does require a bit of a learning curve and might require more significant changes than it's worth.
As a simpler alternative, I think you'd be better suited using a data structure that has a Key-Value pair like a Dictionary as opposed to an array or a list. This will make it easier to both create and look up the data. You can see an example of how to build a Dictionary like this in the sample code below.
// We'll assume a single item has been stored in a variable called myItem
Dictionary<string, string> neutralDict = new Dictionary<string, string>();
// Get the raw XML of the item object and loop through it to get the property names and values
var nd = myItem.node;
foreach (XmlNode child in nd.ChildNodes)
neutralDict.Add(child.LocalName, child.InnerText);
// We can now easily retrieve our data
string itemConfigId = neutralDict["config_id"];
string itemCreatedOn = neutralDict["created_on"];
This sample code is just intended to show the general idea of mapping an Aras Item into a Dictionary, so it's not intended to handle cases like relationships or item properties.
