angela's avatar
How to color full federated items in the grid?
Hi, maybe somebody has an idea how to solve this one. I have a full federated ItemType that contains a couple of yes/no columns. The data is displayed as standard grid in Aras. I want to highlight ...
  • Meismart's avatar
    I have had the same requirement, I queried the SQL as normal. but I processed the result to add the CSS to the returned AML.
    This is an extract of my code, it shows you the process I used (note this will need to be edited to provide the desired results):
    //sRes is an item representing the result of my SQL, perform the query here
    string AML = "";
       AML += "<SOAP-ENV:Envelope xmlns:SOAP-ENV=\"http://schemas.xmlsoap.org/soap/envelope/\" xmlns:i18n=\"http://www.aras.com/I18N\"><SOAP-ENV:Body><Result>";
    if (sRes.getItemCount() < 1)
       AML += "<Item type=\"Activity2\" action = \"get\" id=\"" + "No Results" + "\">";
       AML += "</Item>";
    else if (sRes.getItemCount() > 1000)
       AML += "<Item type=\"Activity2\" action = \"get\" id=\"" + "Too Many Results" + "\">";
       AML += "</Item>";
    else
    for (int i = 0; i < sRes.getItemCount(); i++)
        string rw1 = sRes.getItemByIndex(i).getProperty("a2id",i.ToString() + ". Unable to Promote Multiple Items")
    //Get the Yes/No values
        string act2_pending = sRes.getItemByIndex(i).getProperty("act2_pending","");
        string act2_active = sRes.getItemByIndex(i).getProperty("act2_active","");
        string act2_drafted = sRes.getItemByIndex(i).getProperty("act2_drafted","");
        string act2_supplier = sRes.getItemByIndex(i).getProperty("act2_supplier","");
        string act2_manager = sRes.getItemByIndex(i).getProperty("act2_manager","");
        string act2_complete = sRes.getItemByIndex(i).getProperty("act2_complete","");
        string act2_notrequired = sRes.getItemByIndex(i).getProperty("act2_notrequired","");
        string act2_mp_pic = sRes.getItemByIndex(i).getProperty("act2_mp_pic","");
        string act2_mp_mgr = sRes.getItemByIndex(i).getProperty("act2_mp_mgr","");
        AML += "<Item type=\"Activity2\" action = \"get\" id=\"" + rw1 + "\">";
    //AML is a string representing the AML to be returned
    //populate the AML Item
        AML += "<act2_drafted>" + act2_drafted + "</act2_drafted>";
        AML += "<act2_supplier>" + act2_supplier + "</act2_supplier>";
        AML += "<act2_manager>" + act2_manager + "</act2_manager>";
        AML += "<act2_complete>" + act2_complete + "</act2_complete>";
        AML += "<act2_notrequired>" + act2_notrequired + "</act2_notrequired>";
        AML += "<act2_mp_pic>" + act2_mp_pic + "</act2_mp_pic>";
        AML += "<act2_mp_mgr>" + act2_mp_mgr + "</act2_mp_mgr>";
    //CSS represents the fields that should be populated (note: these properties are Boolean "1" or "0").
        string CSS = "<css>";
        if (act2_pending !="0") CSS += ".act2_pending{background-color:PINK;};";
        if (act2_active !="0") CSS += ".act2_active{background-color:Tomato;};";
        if (act2_drafted !="0") CSS += ".act2_drafted{background-color:DarkOrange;};";
        if (act2_supplier !="0") CSS += ".act2_supplier{background-color:Thistle;};";
        if (act2_manager !="0") CSS += ".act2_manager{background-color:Gold;};";
        if (act2_complete !="0") CSS += ".act2_complete{background-color:LawnGreen;};";
        if (act2_notrequired !="0") CSS += ".act2_notrequired{background-color:Silver;};";
        if (act2_mp_pic !="0") CSS += ".act2_mp_pic{background-color:Plum;};";
        if (act2_mp_mgr !="0") CSS += ".act2_mp_mgr{background-color:Plum;};";
        CSS += "</css>";
        AML += CSS;
        AML += "</Item>";
    //return the AML as an item collection to view
    AML += "</Result></SOAP-ENV:Body></SOAP-ENV:Envelope>";
    Item iRes = inn.newItem();
    iRes.loadAML(AML);
    return iRes;
