Thanks Chris. Works now!!!
But the method says it returns Item, is it returning containing the item data because its called from client?
public Item applyMethod( string methodName, string body )
getIdentityList - I tried this, but looping through the results and adding to the list took visible performance hit. Trying to convert to sql as I am going 2 levels in the Identity tree as you can see from SQL. Also, this piece of code need not go through access check as per our implementation
Hi amitosh,
I believe you're looking at the description of the applyMethod function available from the Innovator class in the IOM which does return an Item. The functions available from the aras object in a JavaScript method don't map directly with the functions available from the Innovator object in a server method even though some of them will occasionally share the same name.
A JavaScript representation of the Innovator object is available through a client method, however. If we use this Innovator object (available from aras.IomInnovator), a nicer way of writing the sample I provided in my last comment would instead be:
var res = aras.IomInnovator.applyMethod("NOV_Identity_Details", "body");
Since this function is called from an Innovator object, the return value is an Item object, so it will save you from needing to any manual conversion from a string to an Item.
Hope this helps!
- Amitosh_Tripathy7 years agoCreator I
perfect! thanks for the update. Works as expected now [emoticon:c4563cd7d5574777a71c318021cbbcc8]
