How can i create new permission and add that in
How can i add new permission and add on add
I am using the following mode, it is creating permission but not adding it
[embed:dc8ab71f-3b98-42d9-b0f6-e21e02a0f8e2:b254bcb3-f5a7-4a5f-b41e-556278def9a4:type=text&text=Innovator%20inn%20%3D%20this.getInnovator%28%29%3B%0D%0Astring%20docid%20%3D%20this.getProperty%28%22id%22%2C%22%22%29%3B%0D%0AItem%20permissions%20%3D%20this.newItem%28%22Permission%22%2C%20%22add%22%29%3B%0D%0Apermissions.setProperty%28%22name%22%2C%20docid%29%3B%0D%0Apermissions%20%3D%20permissions.apply%28%29%3B%0D%0Athis.setProperty%28%22permission_id%22%2C%20permissions.getID%28%29%29%3B%20%20%20%0D%0A%09return%20this%3B]
Hi Haider
I'm able to create permission and attach it to the item. Between which user account are you using ? I tried to use Super User and it is working but it will not work for the normal user as there is no access defined for the permission added. I added creator to the permission which is getting created and provided update access.
Use below method (onBeforeAdd)
string docid = this.getID();
Item permissions = this.newItem("Permission", "add");
permissions.setProperty("name", docid);
Item access = this.newItem("Access", "add");
access.setProperty("can_get","1");
access.setProperty("can_update","1");
access.setProperty("can_discover","1");
access.setProperty("can_change_access","1");
access.setProperty("related_id","8FE5430B42014D94AE83246F299D9CC4");
permissions.addRelationship(access);
permissions = permissions.apply();
this.setProperty("permission_id", permissions.getID());
return this;Thanks
Gopikrishnan R
