Alexis_Amirtharaj's avatar
Hiding/showing columns in relationship grid based on field values
How can I hide/show columns in the relationship grid based on the changes in the dropdown box of the parent form?
  • Hello Alexis,
    If you want to hide columns of relationship use following code.
    Hide Column:
    parent.findCurrentRelationshipsTab().document.getElementById('gridTD').children[1].getElementsByTagName('th')[ColumnIndex].setAttribute('style','display:none;');
    Show Column:
    parent.findCurrentRelationshipsTab().document.getElementById('gridTD').children[1].getElementsByTagName('th')[ColumnIndex].setAttribute('style','text-align:left;text-align:center;width:100px');
    Thanks,
    Praful Gurav
    • Kailas's avatar
      Kailas
      Hi Praful, I have tried this code on onFormPopulated event but it throwing an error "Event handler failed with message: TypeError: Cannot read properties of undefined (reading 'getElementsByTagName')"
      I am using ColumnIndex value [1]
      While debugging code i was getting error as undefined for below code:
      Thanks,
      Kailas
  • Suhas's avatar
    Suhas
    Creator III
    Hello Alexis,
    Attach your method on change of dropdown box property event.
    please find the below code to hide/show the relationship tab
    //based on your condition (dropdown box value)  set 0 or 1 in below code
    //0-means hide the relationship
    //1- means show the relationship.
    parent.relationships.relTabbar.setTabVisible(top.aras.getRelationshipTypeId("your_relationship_name"), 0);
    Regards,
    Suhas
