8 years agoCommunity Manager
Hi Klaus,
It is not possible to manually set the keyed_name of an item using the AML above; the keyed_name will always be set to the properties marked by the Keyed Name Order column on an ItemType. If no properties are marked, the keyed_name will be set to the ID of the item. Because of this, searching on the keyed_name will not work unless you know the ID of the new item ahead of time.
Because the merge action requires some criteria to be passed, I'd recommend using a where clause like below.
<AML>
<Item type="Member" action="merge" where="member.source_id = '@1' and member.related_id = '@2'">
<source_id>@1</source_id>
<related_id>@2</related_id>
</Item>
</AML>
