ECO Validation
Good day all. I am trying to set up a validation (C#) for a field to make sure it is completed before moving to the next step in the Workflow Process. I have seen some information for validating a checkbox in C# and some form of validation with VB (I don't know VB). I can't seem to get this to work. The coding I have tried either stop everything or don't stop anything. I added the method to the Workflow Map Path as a Pre Method. I would appreciate any help with identifying what I have missed. Thank you.
Change Request - sm_DEMO_NDR (it is a testing ground for me)
Property - sm_change_end_state
| Innovator inn = this.getInnovator(); Item controlledItem = this.apply("s_Get Controlled Item"); string is_completed = controlledItem.getProperty("sm_change_end_state"); if (is_completed =="") return inn.newError("Must be complete!"); return this; |
Innovator inn = this.getInnovator(); // Set up the query Item. if (qryItem = "") return inn.newError("Please select appropriate End State.");
| Innovator inn = this.getInnovator(); Item endState = this.newItem("sm_DEMO_NDR","get"); string state = endState.getProperty("select","sm_change_end_state"); if (this.endState == "") {return inn.newError("Please select appropriate End State.");}; |
Seems like you have assigned an id to get a controlled item. This is my variant based on an original Aras sample:
// Get the controlled item.
Item controlledItem = this.newItem(this.getAttribute("type"), "labs_GetControlledItemCSharp");
controlledItem.setID(this.getID());
controlledItem = controlledItem.apply();
if (controlledItem.getItemCount() != 1)
return inn.newError("Error retrieving the controlled item: " + controlledItem.getErrorDetail());
string teamId = controlledItem.getProperty("team_id","");
