eli_donahue
9 years agoCommunity Manager
Hi Ketan,
The first approach will work with the following url format:
localhost/.../vaultserver.aspx&vaultId={id}
You will also need to add the following line to your VaultServerConfig.xml file and restart IIS to allow access to the vault file without authentication:
<enforce_user_credentials>0</enforce_user_credentials>
