Hi Christopher,
I tried to add the classification as well with the same value I had provided during the time of creation. Now I am getting a different error:
<SOAP-ENV:Body>
<faultcode>SOAP-ENV:Server</faultcode>
<faultstring><![CDATA[No items of type re_Requirement found.]]></faultstring>
<detail>
<af:legacy_detail><![CDATA[No items of type re_Requirement found.]]></af:legacy_detail>
<af:exception message="No items of type re_Requirement found." type="System.Exception" />
</detail>
</SOAP-ENV:Fault>
</SOAP-ENV:Body>
</SOAP-ENV:Envelope>
Hi archan,
Have you updated the where clause in your AML to include a check for the classification like "... and [re_Requirement].classification = 'Text' ..."
- archan967 years agoIdeator III
Hi Christopher,
Yes I tried that. I was adding it in the body first. Now I tried to add it in the where clause, and I am getting that error again which I was getting in the first place.
Here is my AML DOM, just trying a simple update by changing the requirement title by appending GUID to it
<Item isNew="1" isTemp="1" type="re_Requirement" action="edit" where="[re_Requirement].config_id = '68A75D9AAD4346E9A067B8A83C268657' AND [re_Requirement].is_current='1' AND [re_Requirement].classification = 'Requirement'">
<req_title>Test Requirement6247822e-20f9-4f7c-aa60-424360271702</req_title>
</Item>The same error:
<SOAP-ENV:Envelope xmlns:SOAP-ENV="">schemas.xmlsoap.org/.../" xmlns:i18n="">http://www.aras.com/I18N">
<SOAP-ENV:Body>
<SOAP-ENV:Fault>
<faultcode>1</faultcode>
<faultactor />
<faultstring>Classification cannot be changed after saving the item.</faultstring>
</SOAP-ENV:Fault>
</SOAP-ENV:Body>
</SOAP-ENV:Envelope>- christopher_gillis7 years agoCommunity Manager
I believe to work around this issue you'll need to include the requirement in both the where clause as well as the body.
<classification>Requirement</classification>
</Item>Any properties in the body of an edit or update will be applied as changes to any items that satisfy the where condition specified in the attribute. Because of the inability to change the classification of the requirements, you'll need to run this update once per-classification by specifying the classification in both the where clause and the body.
Hello Christopher,
Apologies for the delayed reply. Unfortunately, including classification in where clause and body did not work. Now I am getting this error again:
<SOAP-ENV:Body>
<detail>
</detail>
</SOAP-ENV:Fault>
</SOAP-ENV:Body>
</SOAP-ENV:Envelope>This is the AML being created:
<Item isNew=\"1\" isTemp=\"1\" type=\"re_Requirement\" action=\"edit\" where=\"[re_Requirement].config_id = 'D4C1DBC53A464A179043F3EC01BBEAB1' AND [re_Requirement].is_current='1' AND [re_Requirement].classification = 'Test'\">
<req_title>Test Requirementff341cb6-cb81-4425-a144-067e3b973310</req_title>
<classification>Test</classification>
</Item>I am stuck now. Please suggest any other solution or something else I can do to update Requirement using the API. Is the same error being reproduced at your end as well ?
