michelle's avatar
michelle
8 years ago
Class Structure don't show one of list by identity
Hi ItemType 【Class Structure】 I add three item AAA、BBB、CCC. I create two Identity -->Identity_A  、Identity_B. When Identity_A  login and  click classification show list,I want  list just show  AAA 、BBB 2 item. When Identity_B login and  click classification show list, I want list  just show BBB、CCC item. How can to setting or write method control. I don't know where event can I use.
  • Hello, It is possible to disable classifications for certain users. You can control this under the Can Add relationship tab of the ItemType that these classifications are defined for. Under this tab, you can use the Class Path column to control which classifications each group of users has access to. In this case, your Can Add settings would look something like the example below.
    Name           |    Can Add    |   Class Path
    Identity_A     |       True          |     AAA Identity_A     |       True          |     BBB Identity_B     |       True          |     BBB Identity_B     |       True          |     CCC
    Note that this will not completely hide the disabled options from the classification window, but it will gray them out and make them unable to be selected. Chris ____________________________ Christopher Gillis Aras Labs Software Engineer
  • Thank you so much for responding to my question.  This setting OK.
