Hello Chirag ,
By using customization you can add background color to specific cell based on state condition.
It is possible in TGV to color the state cell to those part which has released state.
In a TGV editor you can apply your custom CSS. Please refer below screenshot.
As well as you may need to add same css class in "tgvViewer.css" and "tgvViewer.min.css" file.
angela Please let me know if anything is required.
Regards,
Suhas
- angela1 year agoCatalyst II
Hi Suhas ,
many thanks for this answer! I was looking for such a solution since years!
I did an quick test in Innovator 12, but only got the plain text from the "Text Template" in my TGV. The variables for Part.state still worked, but the rest was displayed like regular text.
Which Innovator version did you use for this solution? Is this something official Aras introduced in any of the new releases?
- eli_donahue1 year agoCommunity Manager
Hi Suhas ,
I tested this on R31 and saw the same behavior Angela described. Do you perhaps have other customizations in the code tree?
- suhas_j_steepgraph_com1 year agoIdeator I
Yes eli_donahue , We have to modified code files for same.
In templates.tsx we need to do below changes
code addition: line 218-line 234In tgvViewer.min.css file we need to do below changes:
I hope it will work.
Please let me know in case of anything.- angela1 year agoCatalyst II
Hi Suhas,
many thanks for the update on this one! Which Innovator version did you use for your tests? It´s definitely an I14. But is it something higher than Release 30?
I think I know how the solution might look like. It should be an I14 a code tree mod. I assume it´s similar to the way "item property" renderings work (icon + link + link styling).
I don´t want to test this one in my Innovator 12, cause the TGV code has changed a lot between I12 and I14. But I will give it a try as soon I have access to some I14.
