Change 'Save As' to use part number sequence instead of adding Copy Of in the part number field?
- 6 years ago
Hi m2sawyer
Use below steps to update part number. (Input is Sequence Name used to generate part part number. I used Simple ECO sequence number for reference. Update and verify)
Step 1: Create new server method and copy below code
Step 2: Open Part Item type and add this method under server events (Event : On After Copy)
Step 3: Save and Unlock the Item type
Aras.Server.Security.Identity plmIdentity = Aras.Server.Security.Identity.GetByName("Aras PLM");
bool PermissionWasSet = Aras.Server.Security.Permissions.GrantIdentity(plmIdentity);
try
string sequence = "Simple ECO";
Item newPartItem = inn.newItem(this.getType(), "edit");
newPartItem.setID(this.getID());
if (!string.IsNullOrEmpty(sequence))
string newNumber = inn.getNextSequence(sequence);
newPartItem.setProperty("item_number", newNumber);
newPartItem = newPartItem.apply();
finally
if (PermissionWasSet) Aras.Server.Security.Permissions.RevokeIdentity(plmIdentity);
return this;Thank You
Gopikrishnan R
