Morgan's avatar
Morgan
Creator III
Cannot insert the value NULL into column 'NAME',
Hi all,
I recently exported updates to the CAD item type from a development environment to our QA testing environment. I am running into an error when updating the NAME property to required:
Cannot insert the value NULL into column 'NAME', table 'ArasTest_12sp14.innovator.CAD'; column does not allow nulls. UPDATE fails. The statement has been terminated. in SQL: [ALTERTABLECOLUMN]
Any ideas? The field can be updated in the environment in which I exported without issue. Did I maybe miss something in my package definition?
  • I figured it out.
    There are already items in this database with no name attribute.
  • Yeh, if you have a non-nullable column, with no default value or if you provide no value it will error. I hate when SQL server is throwing this error.
    pay for term paper
  • I figured it out.
