Hi Jukka,
where you successful with this topic?
Since I while I want to achieve similar topics (custom XML input in TGV and coloring) but so far only had mixed results.
I think both topics are possible. Regarding coloring there seem to be a view of not integrated components inside Innovator already.
- Kai_Kircher4 years agoCreator I
Hey Angel,
Ever get the TGV coloring working? I'm trying to find some examples of where to start, and running into very little helpful stuff out there.
Thanks,
Kai- angela4 years agoCatalyst II
Well, see my "Trees are my nemesis in 2022" answer in this post:
No, I weren´t able to do TGV coloring yet. The T in TGV stands for torture and Aras enjoys to see me suffering. [emoticon:752f32bcc91d4a448db162742a877a4a]
I found a few references regarding styling inside the used ItemTypes, but they were dead ends.
Aras once showed a colored tree in a webinar:
But to my knowledge they didn´t use TGV for the example, but the underlying tree-engine to build a full custom tree. At least that was the answer I got.
I still wait to find the perfect sample for this one.
I had an alternative idea, but didn´t do much testing yet:
So far we can do coloring in the regular grid pretty easily with the css property. We can hardcode the css property or fill it dynamically with an onAfterGet Method. The css content is simply thrown as inline stylesheet to each grid row.
I discovered that standard grid and TGVs are not so much different. They actually seem to share more code then expected.
But so far TGVs ignore the CSS property. If we could change QB/TGV engine to include the CSS property, coloring would be pretty easy. Let me know your result :)
