jeff_stroh's avatar
jeff_stroh
4 years ago
Button not adhering to CSS
Hello, I've got a button with very simple CSS (below).  Problem is, the button isn't adhering to the code: {$this field rule} input; input[type="button"]{ height: 50px; width: 50px; } input[...
    4 years ago
    Regarding Aras buttons:
    Which tab do you use to do your styling? Field CSS or Form CSS?
    1. Your first code works in 'Form CSS' (overall Form styling) when you remove {$this field rule} input; .
    2. Your first code works in 'Field CSS' (individual element styling) when you remove input[type="button"] ;
    Regarding html buttons.
    Your button html code contains multiple errors. Your function call is creative (but wrong :-) ) and you mix ' with ". Compare with this one:
    <input type="button"
      onClick="myfunction();"
      style="height:40px;cursor:pointer;width:40px;"
    <script>
    function myfunction() {
      alert("x");
    </script>
    Instead of using tons of buttons, I personally would use a html table for this use case. Harder to design, but a lot easier to maintain. Of course a matter of taste.[emoticon:c28b2e4cc20f4ba28d1befdba6bed29c]
