Hamdi_Kendil's avatar
Hamdi_Kendil
Browse the versions of an item
Hi everyone ,
I'm currently trying to implement a C# method that should be able to browse all the versions of a
Part Item ,
thus we can read the states of the different versions and promote them .
but the problem is that I don't know how to get the versions of an Item .
Does anyone know how to solve this issue please ?
Thanks in Advance
Hamdi
  • Hi Hamdi,
    in order to get all versions of an item you can query for items with a specific config_id (stable throughout all versions of an item) by specifying the condition "is not null" on the id property.
    In AML:
    <Item type="Part" action="get">
        <id condition="is not null" />
        <config_id>configIdOfTheItem</config_id>
    </Item>
    or using IOM (assuming we have an Innovator object called inn):
    var allVersions = inn.newItem("Part", "get");
    allVersions.setProperty("config_id", configIdOfItem);
    allVersions.setPropertyCondition("id", "is not null");
    allVersions = allVersions.apply();
    Hope this helps,
    C
    • S_Vinoth's avatar
      S_Vinoth
      How I can pass multiple Config ID?
      I tried this way, But is not working for me, Can you please suggest here?
      let item = inn.newItem('Part', 'get');
      item.setProperty('classification', 'TYPE-A');
      item.setPropertyCondition("NAME", 'like');
      item.setProperty("NAME", `%Value_2%`);
      item = item.apply();
      let config_Id = []
      for (let i = 0; item.getItemCount() > i; i++) {
          var current_Item = item.getItemByIndex(i);
          config_Id.push(current_Item.getProperty("config_id"))
      let all_version = inn.newItem('Part', 'get');
      all_version.setProperty('config_id', config_Id.join(","));
      all_version=all_version.apply();
      Thanks
      Vinoth S
      • eli_donahue's avatar
        eli_donahue
        Hi Vinoth,
        I think you’re pretty close. Try these two tweaks to the last few lines of your method:
        all_version.setProperty('config_id', config_Id.join("|"));
        all_version.setPropertyCondition('config_id', 'like');
    • Hamdi_Kendil's avatar
      Hamdi_Kendil
      Hi Cogres ,
      Thank you for your response ,
      it was really Helpful ,but just to know , I am using a C# method
      I have an other question please ,
      In my code there is a case where I should promote the current Item
      so here is the code I have used :
      //Obtain the Innovator instance from the Context Item
      //Get the hexa id of the current EDM Part item
      string ID = this.getID();
      //Get the latest Part item with id "ID"
      Item latest = inn.getItemById("Part",ID);
      //Get the latest Part state
      string latestate = latest.getProperty("state");
      if(string.Equals(latestate, "serie", StringComparison.OrdinalIgnoreCase)){
      //get the list of generations of the current Part Item
      String config_id = latest.getProperty("config_id");
      Item allVersions = inn.newItem("Part", "get");
      allVersions.setAttribute("orderBy", "generation");
      allVersions.setProperty("config_id", config_id);
      allVersions.setPropertyAttribute("id", "condition", "is not null");
      //get the Item count of the versions
      int vercount = allVersions.getItemCount();
      for(int i=0; i<vercount; i++)
      Item ItemI = allVersions.getItemByIndex(i);
      string state = ItemI.getProperty("state");
      //string generation = allVersions.getItemByIndex(i).getProperty("generation");
      if(string.Equals(state, "serie", StringComparison.OrdinalIgnoreCase))
      string NextState = "Auslauf";
      ItemI.setAction("promoteItem");
      ItemI.setProperty("state", NextState);
      ItemI = ItemI.apply();
      return latest.apply();
      the code written in Bold Format is what I have used to promote the Item
      is these instructions are Correct ?  , or do you have a better method ?
      Thanks in Advance
      Hamdi
