Hi rif6894,
If you copy the following into your onActivate method, it should do what you need (tested for Innovator 12.0, older versions might not support all of the C# functionality in the code). Note my "ECR coordinator" property on the ECR has name "ecr_coordinator" and the ID of my "ECR coordinator" identity is '1999BBE8AC784D1C8E99A74FC6C9E537'.
EcrCoordinatorHandler ecrHandler = new EcrCoordinatorHandler(this);
return ecrHandler.OnActivate();
public class EcrCoordinatorHandler
private readonly Innovator _innovator;
private readonly Item _thisItem;
public EcrCoordinatorHandler(Item item)
_thisItem = item;
_innovator = item.getInnovator();
public Item OnActivate()
Item ecrInstance = GetEcrInstance();
string ecrCoordinatorId = ecrInstance.getProperty("ecr_coordinator");
return string.IsNullOrWhiteSpace(ecrCoordinatorId)
? _innovator.newError("No ecr_coordinator found.")
: SetEcrCoordinatorAssignments(ecrCoordinatorId);
private Item SetEcrCoordinatorAssignments(string ecrCoordinatorId)
Item activityAssignment = _innovator.newItem("Activity Assignment", "edit");
string whereClause =
$"innovator.[Activity_Assignment].source_id='{_thisItem.getID()}' AND innovator.[Activity_Assignment].related_id='1999BBE8AC784D1C8E99A74FC6C9E537'";
activityAssignment.setAttribute("where", whereClause);
activityAssignment.setProperty("related_id", ecrCoordinatorId);
return activityAssignment.apply();
private Item GetEcrInstance()
Item workflow = _innovator.newItem("Workflow", "get");
workflow.setAttribute("select", "source_type, source_id");
Item workflowProcess = _innovator.newItem("Workflow Process", "get");
Item workflowProcessActivity = _innovator.newItem("Workflow Process Activity", "get");
workflowProcessActivity.setProperty("related_id", _thisItem.getID());
workflowProcess.addRelationship(workflowProcessActivity);
workflow.setRelatedItem(workflowProcess);
workflow = workflow.apply();
Item controlledItem = _innovator.newItem();
controlledItem.setAction("get");
controlledItem.setAttribute("typeId", workflow.getProperty("source_type"));
controlledItem.setID(workflow.getProperty("source_id"));
return controlledItem.apply();
Tested it for a setup similar to yours and it worked as intended. No idea if this is all kosher, but since no one else has answered in three days, I thought I might as well.
The code is in such a shape because I simply adapted something I already had in my own "ArasHelpersAndHandlers" library (I had a use case similar to yours and only had to change a bit of the code). You can, of course, change that on your end so that you only have the method, without any class or anything like that.
Cheers,
C
C
Thanks for your response.
I have re-written in VIsual Basic, using your schema and approach.
Works okay, so thank you for your assistance.
Regards
RiF
