Meismart's avatar
Meismart
Creator III
aras_x003A_uniqueness_helper
I have a noticed the property 'aras_x003A_uniqueness_helper' on previous revisions of an item, what is this property used for?
  • Hello,
    Angela did a good job of summarizing what this property is used for, but I'll try to rephrase it. When a versionable ItemType has some number of unique properties set on it, this uniqueness_helper is used to differentiate two versions of the same item that may have the same combination of values for the unique properties. As stated previously, this is a system property that is automatically set and can be ignored for all practical purposes.
  • I remember that I have seen this one before, but I cannot remember in which context. Were do you see this property? In the database? In the client?
    • Meismart's avatar
      Meismart
      Creator III
      I can query this property in SQL and AML using the Nash tool. I would like to know what it is used for behind the scenes. It seems to be a duplicate of the item id.
        The uniqueness property is used on ItemTypes which are versionable, like Part, Document, etc. . Non versionable ItemTypes like User will not have this property.
        The property itself will be used as soon as you create a new revision of an item. The latest version of an Item will not have this property, while in the previous revisions the uniquness_helper is identical to the item id.
        It´s a system property, automatically set on database level. I don´t know the exact purpose, but it´s propably used to keep data consistent when using revisioning. You shouldn´t have to take care for this one.
