frank_guarino_murata_com
1 year agoCreator III
Any way to instantiate a C# class that is within another method or file?
I have written a C# class helpful for me in refactoring some processing of an older method.
This C# class could prove helpful for other modules which perform the same logic.
Is there anywa...
- 1 year ago
Hi Frank,
This is not possible purely within the Innovator database itself. However, if you extract this class into a custom DLL, it would be possible to reference this DLL from your methods. You can see an example of this in section 8.27 of the Programmer's Guide.
Note that I've linked the Release 33 version of the Programmer's Guide, but this functionality is not new and you should be able to find the relevant section in the Programmer's Guide of whatever version you are using.
Hope this helps!
