Shin_Tanaka's avatar
Shin_Tanaka
Ideator II
Single sign-on to Aras Innovator using a proprietary authentication system
We have built a system that when you log in to a PC, that system can auto-login to multiple systems.
We want to use our own authentication system to automatically log in to Aras Innovator.
I would like some advice.
・Do you have any documentation that would be helpful?
・What information can I provide to get more detailed advice?
  • Former Member's avatar
    Former Member
    Not applicable
    Thank!! for your kind comments.
      Former Member
      Not applicable
      facing a issue help me out? mobdro apk
  • Nice idea! Maybe you can use a REST call from an automatically run script to get a login token? There are a lot of REST API related blog posts in the Aras forum. Getting a login token is an easy task, it would be worth a try.
    • Shin_Tanaka's avatar
      Shin_Tanaka
      Ideator II
      We will try REST API. and please let me know again if anything comes up that you don't understand.
    Former Member
    Not applicable
    Thanks for this. This worked exactly as expected. tellpizzahut
      Shin_Tanaka
      Ideator II
      What features did you work with?
      Please share to the extent possible.
  • If you are looking for ParentVUE MHS Login? Then check here I have given step-by-step details for the Login ParentVUE MHS Portal including a screenshot. Before login into ParentVUE MHS, you should check some basics about ParentVUE portal uses, benefits, and how you can access it.https://parentvue-login.info/
Recent Discussions
