Hi Salini
You're absolutely right—ARAS Innovator 31 comes with a lot of changes compared to version 11, especially in terms of UI and reporting features. Creating an SSR (Self Service Report) now involves a slightly different process.
Here’s a quick guide to help you get started:
Go to TOC > Reporting > Reports
Choose the report type as Self Service and create a new report entry.
Query Definition
Instead of the old filter options, ARAS 31 now uses "Query Definitions" to pull data. You’ll need to create or link a relevant query under this section.
Display Columns
Once your query is connected, select the fields you want to display—this replaces the earlier "Item Properties" setup.
Permissions
Make sure your user role or identity has permission to access the report and query.
Test & Adjust
After saving, run the report in user view to confirm it displays as expected.
It does take a bit of getting used to, but once you're familiar with the new layout, it’s quite effective.
Also, as someone who's been exploring different tools and services for academic and professional support, if you're ever working on leadership-related modules like ILM Level 5 assignments, I found UK ILM Assignment Help services to be really useful, especially when juggling work and learning new platforms like ARAS.
