Trying to creat a link through server side method with AML
AML works in Nash.
When an user is created i want to put his identity into another identity.
This method is plugged on after add event of identity item type.
Could you tell me id i missed someting ? Should i put an apply somewhere ?
Innovator _innovator = this.getInnovator();
System.Diagnostics.Debugger.Launch();
//get id of the identity of the user created
var New_identity = this.getID();
Item New_identity_item = this.newItem("Identity","get");
New_identity_item.setProperty("id",New_identity);
New_identity_item = New_identity_item.apply();
var Is_Alias_1 = New_identity_item.getProperty("is_alias");
if ("1".Equals(Is_Alias_1))
//3007DCA0B6B949A0A0B5E51AF85A6B52 ***_Checker
string aml = string.Format(
<AML>
<Item type = 'Member' action ='add'>
<source_id>3007DCA0B6B949A0A0B5E51AF85A6B52</source_id>
<related_id>{0}</related_id>
</AML>",New_identity);
System.Diagnostics.Debugger.Break();
return this;
Thanks you Slight smile
  • Hello,
    You already pointed out the problem here. :) You should just need to apply the query that you built using something like the sample code below. I've also included some simple validation to make sure the Member is actually created.
    // the aml variable is built above
    Item res = _innovator.applyAML(aml);
    if (res.isError()) {
        // If we're unable to create the Member, return the error so we can see why
        return res;
