hello,
i post that here as a reminder because i was not able to find information about this :
<AML>
<Item type="ItemType" id="0E4B48B11212429DB971*BFB026ADB97" action="edit"> Add / Delete
<allow_private_permission>1</allow_private_permission>
<auto_search>0</auto_search>
<class_structure><![CDATA[<class id="0E4B48B112124*9DB9714BFB026ADB97"><class id="87D3738F6C794C94*E823642A9E50A38" name="Formal" /><class id="D457200A964B48509468B7E5497C9D43" name="Informal" /><class id="D16D866888014CC3A*F06A50B6DA653E" name="**" /></class>]]></class_structure>
<enforce_discovery>1</enforce_discovery>
<hide_where_used>0</hide_where_used>
<history_template keyed_name="Default" type="History Template">3BC16EF9E52B4F9792AB76*CE0492F29</history_template>
<implementation_type>table</implementation_type>
<instance_data>***</instance_data>
<is_dependent>0</is_dependent>
<is_relationship>0</is_relationship>
<is_versionable>1</is_versionable>
<label xml:lang="en">***</label>
<label_plural xml:lang="en">**t</label_plural>
<manual_versioning>0</manual_versioning>
<revisions keyed_name="Default" type="Revision">7FE395DD8B9F4E10907*6A34B733D75E</revisions>
<show_parameters_tab>1</show_parameters_tab>
<structure_view>tabs on</structure_view>
<unlock_on_logout>0</unlock_on_logout>
<use_src_access>0</use_src_access>
<name>***</name>
<Relationships>
<Item type="ItemType Life Cycle" id="B6ABA8AAD6934C6DBF*0A320136B24FE" action="add"> Delete
<class_path>Informal</class_path>
<related_id keyed_name="name" type="Life Cycle Map">582B759C17CC4*979466C730E7ECCFE5</related_id>
<sort_order>256</sort_order>
<source_id keyed_name="**" type="ItemType" name="**">0E4B48B11212429*B9714BFB026ADB97</source_id>
<related_id keyed_name="name" type="Life Cycle Map">582B759C17CC4797946*C730E7ECCFE5</related_id>
<source_id keyed_name="**" type="ItemType" name="GTSI_GTR_SNAPSHOT">0E4B48B11212429DB*714BFB026ADB97</source_id>
</Relationships>
</AML>
