I suppose Innovator V12SP1 supports also REST integration. When I try an example in Postman, it returns the following error;
Hi Chenze,
I believe 12.0 removed the ability to authenticate directly through the headers like this. Instead, you'll need to request a token from the OAuthServer and authenticate using that token. You can check out this blog post on token authentication for some steps on how to do that.
Many thanks Chris. It works now.
Hi Christopher,
i am getting the same error although i did an authentication. See the photo:
Error is
Can you help me with this?
i solved the issue. No need to look at. Thanks
How did you resolved this
I'm also facing the same issue. Can you please help me on this
you see the tab Authorization in the screenshot. Token should be typed there.
Thank you so much.
But now i received the below error
Copyright © 2022 Aras Open PLM Community | Privacy Policy
