Error Invalid redirect_uri
Hi, I installed Innovator12 in Windows 7, I followed the custom installation process and installation is done but when i try to accces through Chrome(Version 75),
1.When I open page
->localhost/InnovatorServer
Error: Invalid redirect_uri.
2.When I open page
->localhost/.../InnovatorServer.aspx
Error: HTTP error 401.0 - Unauthorized
What can I do to resolve this issue.Invalid redirect_uri
  • Hi YoungGo,
    Could you please take a look at your OauthServer/Oauth.config file? Towards the bottom of that file is a list of redirectUris. Could you check to make sure that the value between your ip address and /client/ is InnovatorServer, like you have specified above? The error seems to indicate that somehow the redirectUris were misconfigured.
    AJ
  • Hi AJ,
    Thank your reply. Please see the attached file and screenshot
    I check My OauthServer/Oauth.config file
    <redirectUris>
    <redirectUri value="iomapp://token/"></redirectUri>
    </redirectUris>
    I didn't see the URL(http://localhost/InnovatorServer/client) on Oauth.config.
    When I input http://localhost/InnovatorServer/client on chrome browser,it  just like the screenshot shown below.
    01ErrorOAuth.rar
  • I had the same problem. This section of the OAuth.config file had all the URLs. If I entered one, for example "http : //localhost/PPU/Client", in the Browser, it worked. So I just added the yellow marked lines with the URL I needed, and now I don't get that error anymore.
    I hope this helps.
    Regards
