Hi all
Im needing to play around on Aras PLM for my masters thesis but i dont have access to windows server or an IIS server is there a way to install Aras without these? maybe some sort of free to use virtual machine?
Hi all
Hi Duncan,
It looks like you can install IIS on windows 10 home, take a look at this StackEchange post : https://superuser.com/questions/1245472/does-windows-10-home-edition-have-iis.
As far as a database…
Got it working by doing a fresh install, was probably an error with one of the password. thanks all for the help
Aras is IIS application, so it needs Windows + IIS + SQL to run. BUT if you have Windows laptop, you usually can install IIS on that + free SQL Express (DB). So you don't need 'server' for that.
I'm not 100% sure which Windows versions support installing IIS (student?, home?, pro -yes).
Or are you using mac?
//Jukka
I have windows 10 home
Hi Duncan,
As far as a database is concerned, Jukka is correct. You can download the free version of MSSQL and connect your innovator instance to that.
AJ
Thanks ill try that and get back to you
Im stuck on the aras innovator installer now, when i click configure database i get an error:
[Microsoft][ODBC SQL Server Driver][SQL Server] Login failed for user 'innovator'
Are you following the Installation guide which was packaged with the CD Image? Could you post a screenshot of the Installer before you press configure database?
In this example, I will use my student benefits. Therefore, I will take the software from Microsoft as fresh as possible according to the Dreamspark program.
So, make up the task.
Install MS SQL Server 2014; Install the role “Web Server (IIS)” version 8; Install PHP 5.4.24; And, of course, to make all this work in conjunction on Windows 2012 R2 (I will not consider the installation and preparation of the server, of course). essay service
Copyright © 2020 Aras Open PLM Community | Privacy Policy
