Hello, even after reading all available documents related to getting started, I am not able to figure it out, how a Team of engineers with rights can be set up to be able to work on the same projects.
I am wondering if someone is able to provide a guideline.
Unfortunately, ARAS Innovator 11.0 is not self-explained.
Or I have not yet understood it.
Thanks for HELP
Best regards
Andreas
AJ,
thanks for your advises. I have now figured it out, how to give rights to the users.
Is the Assigned Creator information the parameter which controlles the visibility of a part?
I need to set it for each part when creating it.
Andreas
AJ,
When creating a part, the Designated User field must be filled out to make the part useable for the team members.
Is there any way to define a standard?
Otherwise it must be filled out every time when creating a part or any other objects.
