I am installing Aras Innovator on a sandbox server Windows 2016 and MSSQL Express 2014
I am using default setting as recommened in the Aras tourturial on youtube
The Innovator installation fails at the following step: Configure database.
The steps fails when I press Configure Database with the following message:
"[Microsoft][ODBC SQL Server Driver][SQL Server]Password validation failed. The password does not meet Windows policy requirement because it is too short."
I can login to the sql server with the SQL Studio Management tool both with the 'sa' user and the 'innovator' user using SQL Server Authentication
If I make test.udl and use both the 'sa' and the 'innovator' user I can connect to the database.
I got it solved.
Instead of using mssql2014 express I tied with mssqlexpress 2017 together with Innovator 11 SP 12
Also instead of using the sa user in sql authentication to connect to the database I used windows authentication for connection to the database.
Then it worked
