Hello dear ARAS community,
we are a small Company from Germany and we want to install ARAS for our PLM Solutions. Question is : if we install it on our Company Server do we Need to install it on every Computer in the Company or does one compuer suffice ? If then how do we get the link from the Server to other coworkers ? Thank you in advance
You do not need to install Innovator on every computer of your users. Innovator is run as a web application, so as long as your users have the URL they should be able to connect. The URL will consist of your server's name and the virtual path set up in IIS. For example, if you have installed Aras on an Azure VM with named MyVM1.azure.com and you've kept the default name of your Innovator instance of InnovatorServer, the full URL will be myvm1.azure.com/InnovatorServer .
