Did you find the solution for this issue ?
When you see an Item showing as "Restricted", the logged in user does not have enough permissions to Discover/ View the Item. It is probably that the Work Item now has a Life Cycle State (say, Released), that made the permissions deny you access. You should go and change the permissions on the appropriate Item type, for the Released state.
Copyright © 2020 Aras Open PLM Community | Privacy Policy
