How to change Part/Document default revision from alpha to numeric
Hi All,
I am newbie, using the Aras Innovator.
I found the default revision set as alpha. I tried to change it to numeric but causing errors when I try change it back to alpha as all the item created has been used as alpha previously.
Instead of replacing the default "revision" setting from A B C D... to 1 2 3 4.....,  I guess it can be solved by creating a new "revision1" rule with numeric setting.
Then I need to write few codes to employ it only to the part/document type property, however I am not sure how to do it correctly here.
Could anyone teach me here?
I found a post that exactly same happen to me.
--> https://community.aras.com/f/archive/2034/developers-forum---error-comes-when-i-change-default-revision-of-aras-innovator
Highly appreciate your help!
Br, Magga
