Hi
I get an error when installing PE, CE and RE update packages. PE says its an incompatible innovator, but am using the latest versions
Hi
Got it working but uninstilling 12.0 but also deleting the Innovator folder in the C drive manually thereafter.
Glad to hear it. as a rule of thumb, any additional instances you install on your machine need to have a unique file path and web alias. You can have multiple instances on a single machine, but you need to make sure they won't interfere with existing installations.
Thanks !
