Hi
I get an error when installing PE, CE and RE update packages. PE says its an incompatible innovator, but am using the latest versions
Hi
Hi Duncan,
Which version of innovator are you using, and which versions of the applications are you trying to install?
AJ
Hi AJ
Aras Innovator Version 12.0 Build: 13341
CE 12.0R2
PE 12.0R3
RE 12.0R3
Hi Duncan,
12.0 is only compatible with R1 of all the applications you've noted. If you'd like to use the latest versions of applications, you'll need to upgrade your environment to a more recent service pack.
AJ
Thanks, tried installing the SP 8 but get a runtime error
Description: An application error occurred on the server. The current custom error settings for this application prevent the details of the application error from being viewed.
<!-- Web.Config Configuration File --> <configuration> <system.web> <customErrors mode="RemoteOnly"/> </system.web> </configuration>
Do I need to request a license key for the service pack too?
No, your license key should work with all service packs for release 12.
As far as the issue you're seeing, could you give me some more information? Where exactly is this error screen popping up? Before/after login? How did you go about installing your second instance?
The error occurs before the login screen.
I installed the innovator setup within the SP 8 zip file. Just ran the .exe and followed the instructions as for normal setup.
Duncan
I also tried installing with a fresh database
When you installed the SP8 instance, did you install to a unique location? Was the 12.0 instance still installed when you installed the new one?
To the same location. Yes 12.0 was still there
Copyright © 2020 Aras Open PLM Community | Privacy Policy
