By default, the filtered list has 1 filter layer hence 2 dropdown options to select from when creating a new Item. However, I would like to have 2 filters: Division > Process > Security measures. What would be the best approach to set this up?
Hi Dan,
You can check out this community project for an example of how to have three levels of filters. This project was last tested against Aras Innovator 11.0, but I did run a quick test on a local instance of 12.0. The project worked just the same with one minor change which was that I needed to remove the additional Methods and events that this project adds. It seems that there were some updates in Aras Innovator 12.0 that support this kind of multi-level filtering more naturally than in previous versions.
Exactly what I was looking for. Thank you very much Christopher!
Christopher - Can you provide more details on what you changed to run under R12?
I am attempting to use the 'Cascading Filtered Lists' with R12SP16.
All good - worked out how to use cascading selections in R12SP16.
