Hello All ,
how to write data into an external file in HDD programmatically using aras?
not using aras 'CCO.Utilities.WriteDebug(filename,msg)".
Best Regards.
Hafedh.
Hello All ,
Best Regards.
Hafedh.
Hello Hafedh_Elfaleh,
Which kind of file you want to write e.g .xls,xml for simple txt file
Based on file type your code will be differ.
You can write file writing code in your aras method.
Below is the sample code to write a txt file.
StringBuilder
csv = new StringBuilder();
csv.
Append("Sample data");
//file path(string): where you want to save this file physically
string filePath=@"D:\SupplimentLabLoc\abc.txt";
File.WriteAllText(filePath, csv.ToString());
Suhas
