Browse the versions of an item
Hi everyone ,
I'm currently trying to implement a C# method that should be able to browse all the versions of a
Part Item ,
thus we can read the states of the different versions and promote them .
but the problem is that I don't know how to get the versions of an Item .
Does anyone know how to solve this issue please ?
Thanks in Advance
Hamdi
  • Hi Hamdi,
    in order to get all versions of an item you can query for items with a specific config_id (stable throughout all versions of an item) by specifying the condition "is not null" on the id property.
    In AML:
        <id condition="is not null" />
        <config_id>configIdOfTheItem</config_id>
    or using IOM (assuming we have an Innovator object called inn):
    var allVersions = inn.newItem("Part", "get");
    allVersions.setProperty("config_id", configIdOfItem);
    allVersions.setPropertyCondition("id", "is not null");
    allVersions = allVersions.apply();
    Hope this helps,
    C
  • 0 オフライン in reply to cogres
    Hi Cogres ,
    Thank you for your response ,
    it was really Helpful ,but just to know , I am using a C# method
    I have an other question please ,
    In my code there is a case where I should promote the current Item
    so here is the code I have used :
    //Obtain the Innovator instance from the Context Item
    //Get the hexa id of the current EDM Part item
    string ID = this.getID();
    //Get the latest Part item with id "ID"
    Item latest = inn.getItemById("Part",ID);
    //Get the latest Part state
    string latestate = latest.getProperty("state");
    if(string.Equals(latestate, "serie", StringComparison.OrdinalIgnoreCase)){
    //get the list of generations of the current Part Item
    String config_id = latest.getProperty("config_id");
    Item allVersions = inn.newItem("Part", "get");
    allVersions.setAttribute("orderBy", "generation");
    allVersions.setProperty("config_id", config_id);
    allVersions.setPropertyAttribute("id", "condition", "is not null");
    //get the Item count of the versions
    int vercount = allVersions.getItemCount();
    for(int i=0; i<vercount; i++)
    Item ItemI = allVersions.getItemByIndex(i);
    string state = ItemI.getProperty("state");
    //string generation = allVersions.getItemByIndex(i).getProperty("generation");
    if(string.Equals(state, "serie", StringComparison.OrdinalIgnoreCase))
    string NextState = "Auslauf";
    ItemI.setAction("promoteItem");
    ItemI.setProperty("state", NextState);
    ItemI = ItemI.apply();
    return latest.apply();
    the code written in Bold Format is what I have used to promote the Item
    is these instructions are Correct ?  , or do you have a better method ?
    Thanks in Advance
    Hamdi
