how to Not allow User to change password ?
How can IT set that Not allow User to change password on aras tool bar?
  • Hi Zachary
    You can change the visibility in Client Presentation. Follow below steps
    Step 1: Administrators --> Configuration --> Client Presentation
    Step 2: Click Global hyperlink
    Step 3: Navigate to Command Bar Section tab
    Step 4: Search for com.aras.innovator.cui_default.main_window_main_menu
    Step 5: Double click to Open
    Step 6: Lock the Item
    Step 7: Navigate to Command Bar Item tab
    Step 8: Search for com.aras.innovator.cui_default.mwmm_change_passwd
    Step 9: Change For Identity to Administrators from World
    Step 10: Save, Unlock
    Let me know if it helps.
    Thank You
    Gobikrishnan R
