I was wondering if there are any available documentation about :
- Presentation Configurations
- Command Bar Section
- Command Bar Item
- The structure the methods need to have
Thank you !
AlBer
Thank you !
AlBer
Hi AlBer,
Outside of the blogs that Aras Labs has written, there's no publicly available documentation outlining the CUI data model.
As a general overview of the ItemTypes:
This is a large topic to cover. I'd recommend looking at the blogs and projects that are tagged with CUI for some additional information and examples. Let me know if you have any specific questions that aren't answered by the existing resources. :)
Aras Las Software Engineer
Thank you for your answer.
I was wondering if it is possible to use C# rather than JS in client event methods (for interface interaction purposes) ?
Best regards,
AlBer
Hi AlBer,
Because Aras Innovator is a web application, the methods attached as client events need to be JavaScript. However, it would be possible to contain most or all of your logic inside of a C# method and then call that method from your client method with JavaScript code like below.
aras.applyMethod("Your Method Name", "<your_property>Prop Value</your_property><your_other_property>Prop Value</your_other_property>");
Thank you
