Unable to build project in Visual Studio
We have created a project with template v12.0 in Visual Studio 2019.
- We have created a new method from Visual Studio and we got 11 errors :
- Then we created a method on Aras, and then did "Aras Innovator > Open method from Aras Innovator" which worked. We now have the method in Visual Studio, we can edit it and save it to Aras.
- Yet, the method that come from Aras doesn't build also.
The errors we get are :
1>C:\Users\0berali\source\repos\A12_CPQPOP\Aras12CPQ\ServerMethods\CPQProjectCost\Import\Method\CPQProjetCost\CPQProjetCost.cs(1,7,1,11): error CS0246: The type or namespace name 'Aras' could not be found (are you missing a using directive or an assembly reference?)
1>C:\Users\0berali\source\repos\A12_CPQPOP\Aras12CPQ\ServerMethods\CPQProjectCost\Import\Method\CPQProjetCost\CPQProjetCostWrapper.cs(1,7,1,11): error CS0246: The type or namespace name 'Aras' could not be found (are you missing a using directive or an assembly reference?)
1>C:\Users\0berali\source\repos\A12_CPQPOP\Aras12CPQ\ServerMethods\CPQProjectCost\Import\Method\CPQProjetCost\CPQProjetCostWrapper.cs(17,39,17,43): error CS0246: The type or namespace name 'Item' could not be found (are you missing a using directive or an assembly reference?)
1>C:\Users\0berali\source\repos\A12_CPQPOP\Aras12CPQ\ServerMethods\CPQProjectCost\Import\Method\CPQProjetCost\CPQProjetCostWrapper.cs(24,41,24,45): error CS0246: The type or namespace name 'Aras' could not be found (are you missing a using directive or an assembly reference?)
1>C:\Users\0berali\source\repos\A12_CPQPOP\Aras12CPQ\ServerMethods\CPQProjectCost\Import\Method\CPQProjetCost\CPQProjetCost.cs(27,16,27,20): error CS0246: The type or namespace name 'Item' could not be found (are you missing a using directive or an assembly reference?)
1>C:\Users\0berali\source\repos\A12_CPQPOP\Aras12CPQ\ServerMethods\CPQProjectCost\Import\Method\CPQProjetCost\CPQProjetCostWrapper.cs(29,31,29,48): error CS0246: The type or namespace name 'IServerConnection' could not be found (are you missing a using directive or an assembly reference?)
1>C:\Users\0berali\source\repos\A12_CPQPOP\Aras12CPQ\ServerMethods\CPQProjectCost\Import\Method\CPQProjetCost\CPQProjetCostWrapper.cs(19,27,19,44): error CS0246: The type or namespace name 'IServerConnection' could not be found (are you missing a using directive or an assembly reference?)
Some help would be appreciated, we have been looking for it and couldn't find it.
Best Regards,
Al Ber
