Hi folks ,
I am using Aras innovator 11SP15 in a cloned repository on my computer ,
I 've tried to export existing components from an old database to this repository using the Export.exe application and I staged these
components into the existing repository using the SourceTree , then I runned the script " .\SetupInnovatorHere.bat " to reinstall the software
with the exported elements .
but it always displays the following error
<SOAP-ENV:Envelope xmlns:SOAP-ENV="">schemas.xmlsoap.org/.../"><SOAP-ENV:Body><SOAP-ENV:Fault xmlns:af="'objet 'secured.Project_Task'">www.aras.com/.../faultcode><faultstring><![CDATA[L'objet 'secured.Project_Task' est introuvable ou vous ne disposez pas de l'autorisation nécessaire. in SQL:
EXEC sp_refreshsqlmodule 'secured.Workflow_Task'
EXEC sp_refreshsqlmodule 'secured.Project_Task'
EXEC sp_refreshsqlmodule 'secured.Inbasket_Task'
-- Return empty result to the Innovator server because result is required by the server, otherwise an error will be thrown.
SELECT TOP 0 NULL
it seems that there is a missing module or privilege ( I runned the power Shell as administrator ).
does anyone have an idea about this error ???
thank you in advance .
