Is it somehow possible to use C# string interpolation in server method?
For example:
var text = "the text";
var result = $"This is {text}";
The Innovator's default syntax checker gives an error for this code: Error Number: CS1056, Unexpected character '$'.
Can we make any change or add reference to make that syntax work?
I'm using Innovator server 11.SP12, if that helps.
Khanh
