Error when SQL is specified in "where" attribute in AML
Hi Team,
There is AML that seems to have never been an error before, but somehow it becomes an error.
* Aras version is 11.0SP15.
For example, I remember that SQL could be written in the where attribute like the following AML and IOM code.
At the very least, I was able to execute AML / IOM code written in this way in my previous development (V11.0SP8 environment).
===<AML>========================================
<Item type='CAD Structure' action='get' where="innovator.[CAD_Structure].source_id in (select id from innovator.[CAD] where name = 'TestName')">
===<IOM code>=====================================
Item applyItm = inn.newItem("CAD Structure", "get");
applyItm.setAttribute("where", "[CAD_Structure].source_id in (select id from innovator.[CAD] where name = 'TestName')");
Item resultItm = applyItm.apply();
However, when I run this on my current development project, I get the following error:
<SOAP-ENV:Envelope xmlns:SOAP-ENV='schemas.xmlsoap.org/.../'>
  <SOAP-ENV:Body>
    <SOAP-ENV:Fault xmlns:af='www.aras.com/InnovatorFault'>
      <faultcode>SOAP-ENV:Server.ItemAnalysisException</faultcode>
      <faultstring><![CDATA[Item Analysis Error. Some Items have incorrect attribute/property values syntax. See details for more information.
Details:
Incorrect value: "where="innovator.[CAD_Structure].source_id in (select id from innovator.[CAD] where name = 'TestName')"". Incorrect value explanation: "select" is forbidden in where attribute.
Incorrect value: "where="innovator.[CAD_Structure].source_id in (select id from innovator.[CAD] where name = 'TestName')"". Incorrect value explanation: Item hasn't property referred to column with name "name"
]]></faultstring>
      <detail>
        <af:legacy_detail><![CDATA[Item Analysis Error. Some Items have incorrect attribute/property values syntax. See details for more information.
Details:
]]></af:legacy_detail>
        <af:exception message='Item Analysis Error. Some Items have incorrect attribute/property values syntax. See details for more information.&#xD;&#xA;Details:&#xD;&#xA;Incorrect value: "where="innovator.[CAD_Structure].source_id in (select id from innovator.[CAD] where name = &apos;TestName&apos;)"". Incorrect value explanation: "select" is forbidden in where attribute.&#xD;&#xA;Incorrect value: "where="innovator.[CAD_Structure].source_id in (select id from innovator.[CAD] where name = &apos;TestName&apos;)"". Incorrect value explanation: Item hasn&apos;t property referred to column with name "name"&#xD;&#xA;' type='Aras.Server.Core.ItemAnalysisException' />
      </detail>
    </SOAP-ENV:Fault>
  </SOAP-ENV:Body>
</SOAP-ENV:Envelope>
I get an error message saying that "select" is forbidden in where attribute.
I've seen errors like this for the first time.
What should I do?
Is there something wrong with the syntax ? Is the Aras environment bad ? Has Aras AML / IOM rules changed ?
Regards
