Class Structure(Classification) Field onChange Event
Hi Everybody,
I am want to write a code 'on Change" Event of Classification Property to set one of the drop down field value.
I am not getting success to getProperty Value of Class Structure Property as well as to setProperty of dropdown field.
Please help me on this.
I have tried something like below.
var ECRType = document.thisItem.getProperty("classification","");
if(ECRType == "Document" )
var affectedPartsRequired = document.thisItem.setProperty("affected_items","1");
else
var affectedPartsRequired = document.thisItem.setProperty("affected_items","0");
return this;
  • Hi Kara,
    in the onChange method, you can use
    var classi = getFieldByName("classification").getElementsByTagName("input")[0].value;
    And then switch over classi to set the dropdown value depending on your business logic with
    window.handleItemChange("list_property", "value you want to set");
    Is this what you need?
    C
