How to close relationship search dialog box dynamically?
Hi Team,
I have custom result binding code on 'OnSearch' event. On return of result if it is true it works fine but on false I want to close search dialog box that appear in relationship on click of pick related dynamically.
I tried following method but it is not working.
parent.dialog.close();
Any one can please help how to achieve this?
Thanks & Regards
Gaurav
  • Hi Gaurav,
    your problem sounds quite interesting. Unfortunately, I don't quite understand it completely. Could you provide some more details about your setup, please? Do you have a client event onClick of the "Pick related" button in the standard relationship grid? Could you share/explain some of the code that you implemented, as well?
    If you opened the search dialogue with custom code (and with some onSearchDialog event from a sourcePropertyName parameter that contains your business logic) it should be straightforward to close that window in your custom code as well. Seeing as you have this problem, I assume your setup is different, which is why I'm asking :).
    C
  • Hi Cogres,
    Senario:
    I am using aras innovator 11 SP 12. I have Itemtype A and Itemtype B. Created relationship of Itemtype A in Itemtype B. In related_id property of relationship Itemtype I have wrote one client method for "OnSearchDialog" event. Method is totally running fine. Now I have to put one validation, on satisfying false condition I want to close Search Dialog box dynamically through code. I have tried following different option to close Dialog but it is not working
    1.)  parent.dialog.close();
    2.) this.args.dialog.close();
    Following is my method that check and validate condition and execute code
    ----Method Code(Client Side)----
    bool Result = false; //this is getting initialized dynamically. Currently assuming it has false value
    If(Result)
       //Do Something
    else
       close(); //Need to close Search dialog box on satisfying false condition. Tried above options too.
  • Hi Gaurav,
    Thanks for the clarification!
    Since you did not open the dialog from your own custom code, closing it might be a bit trickier. I've played around with it a little bit, but the only thing I found was the kind of hacky
    document.getElementsByTagName("dialog")[0].close();
    It worked for me in a setup similar to yours (note: I tested this on Innovator 12.0). My onSearchDialog method simply contained
    alert("hi");
    and when clicking "Pick related", it opened the dialog, alerted "hi" and then closed the search dialog.
    Obsiously this approach is not very robust, but maybe it can serve as a starting point for you? Maybe you can find a way to uniquely identify the dialog you opened in your setup (document.getElementsByTagName("dialog")[0] makes me feel kind of uneasy), but I couldn't find anything else so far.
    Maybe someone else knows a more solid approach.
    C
