How to prevent new browser window when logging in to Innovator
Hi Community,
when we login to Innovator, we will first get our login screen that than opens the Innovator application in an additional browser window. We most of the time will loose our tabbed browser view.
Is there a way to prevent the frequent opening of new windows? This behavior is probably very browser depended. I was able to prevent the additional window in Firefox with some modifications of the default:config. But didn´t succed to do the same in Chrome or IE.
Do we have to live with this behavior or are there some alternatives? Is it possible to define the login behavior in a more general way independed from the used browser?
Thanks for any ideas!
  • Hi Angela,
    This is pretty browser-dependent. For Chrome specifically, I've seen people use a browser extension that open popups in new tabs in order to open the Aras Innovator login page in the same browser window as all of their other tabs. I don't know the name of this extension off the top of my head, but you should be able to find it with a bit of looking the Chrome store.
    For a longer-term solution, Aras Innovator 12.0 does away with many if not all of these popup windows and runs Aras Innovator directly inside of a browser tab, so you can use it in an existing window.
  • Hi Chris,
    yes, I have seen people using a Chrome browser extension for this use case. They are an suitable workaround. But as not every companies allows unlimited use of extensions, I wanted to check if there is a more general solution available already.
    This one is not a real important task. It´s often already helpful enough when you can give your end user accurate answers. This avoids that people waste time trying it for themselves. I am very happy that it will work in Innovator 12!
    Thanks!
  • About 20 years ago I made a Music Theory site with an external window for navigation. It used JS and .shtml... And, I'm sure that was on Netscape browser. I'm not certain you can still do the cross-window navigation, but I'd think you could change the initial page to parent and create a relationship. You'd have to touch the source code though.
    1st - Make the initial page you dial into, that subsequently causes the login pop-up send a reference back to itself.
    2nd - Make the JS call that currently opens a new window talk back to the original login page.
    I'd really like this behaviour. I find the v11 behaviour very Web1.0. I do like how v12 works, but there happens to be a lot of custom stuff ontop of our v11 and I still need to look at it (which brought me to this post today because, no!).
    If somebody finds this and is allowed to edit their v11: https://javascript.info/cross-window-communication
