I'm having problems updating an item property using a method that opens a custom dialog. I opened a dialog following the ArasModules.dialog example from https://community.aras.com/b/english/posts/tech-tip-opening-a-custom-dialog-from-a-method, the dialog opens to a form where the user can select an item from a list which is returned in the "res" value of the callback function. Once there, I wanted to set the property of an item to this value, but it seems like i lost the original context item and innovator object after opening the dialog. When I debug in the browser the "this" item is of the [object window] type. The results contain two id strings, and I'm trying to use them to set an "item" property.
I tried defining a new innovator object and setting the property but I can't get it to actually apply the changes.
function callback(res) {
if (res) {
var id_1 = res[0];
var id_2 = res[1];
var inn = new Innovator();
var item_2 = inn.newItem("MyItemType","edit");
item_2.setID(id_2);
item_2.setAttribute("select","MyProperty");
item_2.setProperty("MyPropertyl",id_1);
item_2.apply();
How can I set the property from this context?
/Rick
