Where can I add a favicon.ico / website icon?
Hi Community,
webpages often use a shortcut icon / website icon so uses can identify a website more easily.
I noticed an error message in the browser debugger that my Innovator website searches for a favicon.ico. So I assume Innovator can also use a favicon.
But were can I add this one and where to put the link string? Any ideas?
Thanks!
  • Hello Angela,
    You need to update below 2 files:
    1. default.aspx:
    Path: Aras->Innovator->Client
    Put below 2 lines in head section
     <link runat="server" rel="shortcut icon" href="favicon.ico" type="image/x-icon"/>
     <link runat="server" rel="icon" href="favicon.ico" type="image/ico"/>
    2. Innovator.aspx
    Path: Aras->Innovator->Client->scripts
    Put below line in head section:
    <link rel="shortcut icon" href="favicon.ico">
    Thanks and regards,
    Suhas
  • Hi Suhas,
    I can confirm that these two customization will display the favicon as expected. It´s an thorough solution, as it display the favicon both while login and also in the lauchend Innovator. Should be part of the standard product. Many thanks for your help!
