Implementing User Options like Choose CM Options
I am working on a user option dialog where they can pick and choose some values[logged_in_group to start with]
I have created placeholder properties in Core_GlobalLayout for this. Get_IdentityMembership_Details and Get_AllGroups_Details works fine, GetStoredValueForGroup(The users that do not have a preference created for their identity, I am mapping to World) works too. But I have 2 issues :
- The dropdown in my UI Form is not resizing based on values added, its defined as static inside a Group Box, with x and y co-ordinates as 0,0. But without Group Box too I could not make it hold to a fixed width.
CSS for the dropdown:
{$this field rule} .sys_f_label_container
width: 110px;
{$this field rule}
margin: 5px 0px 5px 0px;
{$this field rule} select
width: 110px;
- After user selects the value, I am not able to capture it. I have a ChooseUserOptionsDialog.prototype.SaveUISelection function, but how to capture the value coming from UI here?
Below is the code for this form onLoad
ChooseUserOptionsDialog = function ()
var inn = new Innovator();
var userid = inn.getUserID();
var logged_in_group = getFieldComponentByName("logged_in_group");
var listGroupsDropDown = [];
document.isEditMode = true;
var body = "<sessionuser>" + userid + "</sessionuser>";
var res = aras.applyMethod("Get_IdentityMembership_Details",body);
var resItem = aras.IomInnovator.newItem(); // Create a new empty item
resItem.loadAML(res); // and then load in the string returned from aras.applyMethod
if (resItem.isError()) {
aras.AlertError(resItem);
return null;
if (resItem.getItemCount() <= 0)
//let user choose any group if he does not belong to any group
var resu = aras.applyMethod("Get_AllGroups_Details");
resItem.loadAML(resu); //and then load in the string returned from aras.applyMethod
return null;
var storedValue = this.GetStoredValueForGroup(userid);//gets existing value from db
var index = 0;
if (resItem.getItemCount() === 0)
//do something for no return
else
for (var i=0;i<resItem.getItemCount();i++)
var currentItem = resItem.getItemByIndex(i);
listGroupsDropDown.push({label: currentItem.getProperty("keyed_name"), value: currentItem.getProperty("id")});
if (currentItem.getProperty("id") === storedValue)
index = i;
}de
logged_in_group.component.setState({
list: listGroupsDropDown,
value : listGroupsDropDown[index].value
Below is the code for Ok button
ChooseUserOptionsDialog.prototype.ApplyChanges = function ChooseUserOptionsDialog_ApplyChanges()
this.SaveUISelection();
top.main.tree.updateTree();
parent.args.dialog.close();
ChooseUserOptionsDialog.prototype.SaveUISelection = function ChooseUserOptionsDialog_SaveUISelection()
debugger;
var groupComponent = getFieldComponentByName("logged_in_group", "");
var userSelectionGroup = groupComponent.value;//Value not getting retrived
body = body+ "<usergroup>" + userSelectionGroup + "</usergroup>";
var res = aras.applyMethod("Set_UpdateUserPreference",body);
return null;
